TwinTurbo.NET: Nissan 300ZX forum - Re: Effects of not having AAC connected?
Subject Re: Effects of not having AAC connected?
Posted by bliZard on June 16, 2008 at 8:30 AM
  This message has been viewed 125 times.
In Reply To Effects of not having AAC connected? posted by Norincokid on June 15, 2008 at 09:10 AM
Message I did the same thing when diagnosing a high idle that was slow to return to normal. I disconnected the AAC and the idle was very consistent - the only problem was that it did not adjust for any loading conditions which made the engine almost stall if the electrical demand was high. I did not experience any problems with hesitation or cutting out. I don't see how the AAC could affect in the way you describe, unless there is a wiring/connector problem that is shorting out.
